Ziti Mobile Edge on ChromeOS (Google Workspace Managed Device) Auto-Closes Immediately After Launch
Environment
  • Device: ASUS Chromebook CX14
  • OS: ChromeOS (latest stable channel)
  • App: Ziti Mobile Edge (Android app from Google Play Store)
  • Management: Device enrolled under Google Workspace (Enterprise/Business)
  • Workspace Policies: Android app restrictions partially controlled by Admin Console
  • User: Logged in with a Google Workspace account
  • External Apps: No other VPN apps or firewalls installed
On a Google-Workspace–managed Chromebook, Ziti Mobile Edge launches for 1–2 seconds and then immediately closes, repeatedly.
Even after the admin unlocked all visible app permissions, ChromeOS reports:
  • “No permissions granted”
  • “Allowed permissions: None”
  • Admin Console shows: “This app does not support Android managed configurations.”
When the app attempts to start the VPN tunnel, ChromeOS kills the process, and the device loses internet connectivity until the Ziti app is uninstalled.
  1. Is Ziti Mobile Edge officially supported on ChromeOS (Android container) under Google Workspace device management?
  2. Are there known limitations with ChromeOS VPN APIs or Android VPNService on managed devices?
Are you configuring your managed devices to run ZME via Google EMM?
Yes with Google manged policies
thank you for reporting this. We have not had to look into it yet. Let us do some research and run some tests on our end.
Today i tested with one of client chrome OS PC,
Ziti Mobile Edge installs successfully on ChromeOS, and the JWT enrollment also completes successfully.
However, immediately after the JWT is added and the tunnel attempts to start, the Ziti app crashes and becomes unusable.
After the crash:
  • The Ziti app cannot be opened again
  • Even after reboot, the app closes instantly
  • Clearing data resets app temporarily, but crash always occurs again after next JWT enrollment
Other Android VPN apps (Wireguard, OpenVPN, etc.) work fine on the same Chromebook, which means:
  • Android VPNService API is allowed
  • VPN tunneling is permitted
  • ChromeOS itself is not blocking VPNs
This behavior appears specific to Ziti Mobile Edge on ChromeOS.
Could someone help me fix this? because we have few clients who uses chromebook which is a blocker
@ekoby Could you confirm me, if this is an compatibility issue on chrome OS?
@ekoby I have tested with and without Google workspace rules, Basically it is crashing after JWT is enrolled on chrome OS. So its not policy issue, looks like compatability issue. Can you help us fixing this? We have few clients who are using chromebook we need to make them use our app via ziti. Its kind of blocker. It would be really helpful if some one can take a look and fix it?
Unfortunately I don't have a physical ChromeOS device to test with. It seems to work as expected on a virtual/simulated device.
if you're willing to help us to diagnose this issue:
  • enable ADB bridge on your device (non-managed only) like described here
  • create a bug report: adb bugreport ./bugreport.zip. the zip file may contain information that would help us
Sure i can help you debug . will generate bugreport today and will send you
I’ve attached the Ziti Mobile Edge logs captured on the Chromebook right after enrollment.
Please take a look and let me know what you find.
I only have this Chromebook for today, so I’m available to run any tests you need to help diagnose the issue.
ziti-logs.txt (499.1 KB)
https://controller.xxxxx.com:443 version v1.1.15(0eec47ce3c80 2024-10-02T12:59:41Z)
12-04 18:25:37.073 2420 2441 I ziti-sdk:ziti.c:2042 version_pre_auth_cb(): ztx[1] using OIDC authentication method
--------- beginning of crash
12-04 18:25:37.074 2420 2441 F libc : Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x8 in tid 2441 (native-tunnel), pid 2420 (openziti.mobile)
12-04 18:25:37.199 2507 2507 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstoneProto
12-04 18:25:37.201 142 142 I tombstoned: received crash request for pid 2441
12-04 18:25:37.208 2507 2507 I crash_dump64: performing dump of process 2420 (target tid = 2441)
12-04 18:25:37.901 2507 2507 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-04 18:25:37.901 2507 2507 F DEBUG : Build fingerprint: 'google/dedede/dedede_cheets:13/R142-16433.57.0/14390219:user/release-keys'
12-04 18:25:37.901 2507 2507 F DEBUG : Revision: '0'
12-04 18:25:37.901 2507 2507 F DEBUG : ABI: 'x86_64'
12-04 18:25:37.901 2507 2507 F DEBUG : Timestamp: 2025-12-04 18:25:37.229111789+0530
12-04 18:25:37.901 2507 2507 F DEBUG : Process uptime: 21s
12-04 18:25:37.901 2507 2507 F DEBUG : Cmdline: org.openziti.mobile
12-04 18:25:37.901 2507 2507 F DEBUG : pid: 2420, tid: 2441, name: native-tunnel >>> org.openziti.mobile <<<
12-04 18:25:37.901 2507 2507 F DEBUG : uid: 10075
12-04 18:25:37.901 2507 2507 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0000000000000008
12-04 18:25:37.901 2507 2507 F DEBUG : Cause: null pointer dereference
12-04 18:25:37.901 2507 2507 F DEBUG : rax 00007beaf7d55100 rbx 00007beb47a0f800 rcx 0000000000000086 rdx 00007beb47a4d380
12-04 18:25:37.901 2507 2507 F DEBUG : r8 0000000000000380 r9 0000000000000000 r10 000000000000005a r11 000000000001861a
12-04 18:25:37.901 2507 2507 F DEBUG : r12 0000000000000000 r13 00007beb47a0f8a0 r14 00007beb47a4d000 r15 00007bec11a2a280
12-04 18:25:37.901 2507 2507 F DEBUG : rdi 00007beb47a4d000 rsi 0000000000000000
12-04 18:25:37.901 2507 2507 F DEBUG : rbp 00007beaf76db920 rsp 00007beaf76db8f0 rip 00007beaf7d54e3d
Looks like it is throwing Cause: null pointer dereference kind of bug on installer for chrome book
@ekoby Hi Let me know if you have time today to troubleshoot the chromebook device.
I just noticed this. is there a way you can upgrade controller and routers? Alternatively you can try commenting out oidc section in controller config/yaml file
Oh I've deployed via helm charts so how do I comment out?
i dont see any option of OIDC on configmap of controller
To which version do i need to upgrade to support chromebook? I might need to be aware of breaking changes when i upgrade from 1.15 to stable version.
Alternatively if i can make some tweek to support on current version it would be great so that i can plan for upgrade later.
we (at lease I do) always recommend the latest stable (currently v1.6.9)
I'm running 1.1.5 is it ok to jump to 1.6.9 what would break?
I need you suggestion for upgrade. I'm running controller on gke cluster using helm charts
Let's separate two concepts:
  1. Upgrade the Ziti version you're deploying with Helm
  2. Upgrade the Chart version you're using to deploy Ziti with Helm
For any production environment, you'll benefit from having a test stage as close to it as practically possible so you can prove upgrade candidates.
You're asking about upgrading Ziti version 1.1.5 to 1.6.9. This is not a question of Helm Chart versions, but Ziti versions. You can review the differences in the Ziti CHANGELOG before overriding the Ziti version in your Ziti Controller Helm Chart Release like image.tag: 1.6.9.
After the Ziti Controller Helm Chart was released with default Ziti version 1.1.5, the Helm Chart major version was incremented to v2.0.0 due to a breaking change. To upgrade your chart version, you must perform the one-time migration procedure in the "Breaking Change" section of the controller deployment guide for Kubernetes: Install the Controller in Kubernetes | NetFoundry Documentation. The purpose of the breaking change is to break the dependency on Cert Manager and Trust Manager so they can be upgraded separately from Ziti Controller.
The Ziti Version
Each Helm Chart comes with a default Ziti version. You can upgrade the Ziti version by overriding the image.tag input value. As a rule, there's no reason you shouldn't override the Ziti version to upgrade or downgrade.
:warning: Upgrading Ziti may trigger a datastore migration. If this happens, it will not be possible to downgrade the Ziti version without first restoring a database with the same or lower datastore version required by the target Ziti version. Ziti automatically triggers a database snapshot before migration. The snapshot is stored in the same directory as the Bolt DB file in the controller's storage volume.
The Chart Version
Helm uses semver, and we follow suit, so you may use Helm version constraints to express your level of risk acceptance.
Examples:
  • --version='^2.0.0' means "upgrade unless major (breaking) revision", or
  • --version='~2.0.0' means "upgrade unless minor (features added) revision".
