Hello there,
We're getting some TypeError: argument of type 'NoneType' is not iterable errors when running the router auto enroll script.
Starting binary install
Installing service unit file
Creating config file
Starting Router Enrollment
Successfully enrolled Ziti
File "ziti_router_auto_enroll.py", line 2065, in <module>
File "ziti_router_auto_enroll.py", line 2055, in main
[PYI-5173:ERROR] Failed to execute script 'ziti_router_auto_enroll' due to unhandled exception!
Server certificate chain written to .config/ziti/certs/<cert chain>
Token: <token>
Saving identity 'default' to .config/ziti/ziti-cli.json
Removing identity 'default' from .config/ziti/ziti-cli.json
This is the part of the script that's failing:
wget https://github.com/netfoundry/ziti_router_auto_enroll/releases/latest/download/ziti_router_auto_enroll.tar.gz
sudo tar xf ziti_router_auto_enroll.tar.gz && rm ziti_router_auto_enroll.tar.gz
ROUTER_NAME=${router_name}-$(date "+%s")
sudo ./ziti_router_auto_enroll -f -n \
--controller ${openziti_controller_url} \
--controllerFabricPort ${openziti_controller_port} \
--controllerMgmtPort ${openziti_controller_port} \
--adminUser admin \
--adminPassword ${openziti_controller_password} \
--assumePublic \
--autoTunnelListener \
--disableHealthChecks \
--routerName $${ROUTER_NAME}
ziti edge login ${openziti_controller_url}:${openziti_controller_port} -u admin -p ${openziti_controller_password} -y
ziti edge update identity $${ROUTER_NAME} --role-attributes "routers-${environment}"
ziti edge update edge-router $${ROUTER_NAME} --role-attributes "routers-${environment}"
ziti edge logout
Any ideas?
