I was able to trigger the same error with Debian 12 by running systemctl --user while my user did not have a D-Bus session.
I suspect that you're using the common distribution for Raspberry Pi, Raspbian, and that it is not configured to provision a D-Bus session for the pi user.
This demonstrates the different outcomes depending on whether the shell is invoked as a login session.
❯ lxc shell debian-test -- systemctl --user status dbus.socket
Failed to connect to bus: No medium found
❯ lxc shell debian-test <<< "systemctl --user status dbus.socket"
● dbus.socket - D-Bus User Message Bus Socket
Loaded: loaded (/usr/lib/systemd/user/dbus.socket; static)
Active: active (listening) since Mon 2025-06-23 13:03:18 UTC; 11ms ago
Triggers: ● dbus.service
Listen: /run/user/0/bus (Stream)
Process: 254 ExecStartPost=/bin/systemctl --user set-environment DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/0/bus (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 112954)
Memory: 20.0K
CPU: 3ms
CGroup: /user.slice/user-0.slice/user@0.service/app.slice/dbus.socket
Jun 23 13:03:18 debian-test systemd[248]: Starting dbus.socket - D-Bus User Message Bus Socket...
Jun 23 13:03:18 debian-test systemd[248]: Listening on dbus.socket - D-Bus User Message Bus Socket.
You can perform the same test to confirm the foundational problem is an unavailable D-Bus socket for your logged in user.
And, you can confirm the system-wide D-Bus socket is available. Please respond back to confirm this command works. That will tell me if Raspbian users could run the forthcoming zrok-agent system-wide, privileged service instead of the user service, without any additional configuration.
systemctl status dbus.socket
Normally, the user session is created when you log in via PAM, either a desktop session like gnome-session or via SSH's UsePAM. I'm guessing you're logging in with SSH, so let's first verify that the OpenSSH server is enabled for PAM.
grep -i 'UsePAM' /etc/ssh/sshd_config
And, ensure these packages are installed.
dpkg -l libpam-systemd dbus-user-session
I don't have a RasPi handy to check this out directly, but it's clear the problem is that the pi user doesn't have a "login session," and I suspect this is the default for some distributions like Raspbian.
If that doesn't get you headed in the right direction, please also share the distribution version you're running on your RasPi, and the output of these commands.
loginctl show-user pi
loginctl show-users
loginctl list-users
loginctl list-sessions
