Hi! I'm in a tricky situation: I have a pc with 2 separated Os, both win10, and each Os has a dedicated storage. I've created my zrok account and enabled it on the first Os, and I had zero problems. The problem is when I try to enable the same enviroment in the other Os, so I run the "zrok enable MYTOKEN" command (same token used for the other Os) but the message I get in my powershell tab is the following one:
I'm not self-hosting zrok, as I've read in another thread.
The token is correct as it's the same shown in the proper web console page.
There are no enviroments active on this Os.
Already tried to manually copy the Token istead of right clicking into powershell tab, nothing changed.
If you look in the zrok web console, do you by chance already have 2 environments enabled? If so, you're running into the limit of the free account, which is 2 environments.
If you have environments in the web console that do not correspond to environments that are in use, you can delete them using the "actions" tab.
Got it, I already have two enviroments.
Thanks for the answer. Is possible to exceed this 2 enviroments limit by self-hosting zrok? (I'm interested in try to self host it soon)
