Zrok2 500 error enable
Have a nice day! Need help
Installed on Linux Mint 22.1 Cinnamon
zrok2 version
_
____ __ __ | | __
|_ / '/ _ | |/ /
/|| __/||\
v2.0.0-rc5 [8f8c125e]
zrok2 enable --headless
[ 0.593] INFO main.(enableCommand).run contacting the zrok service...
[ 3.354] ERROR main.(enableCommand).run the zrok service returned an error: [POST /enable][500] enableInternalServerError
there was a problem enabling your environment!
you are trying to use the zrok service at: https://api-v2.zrok.io
$ zrok2 config set apiEndpoint
zrok2 status
Config:
โ•ญโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฎ
โ”‚ CONFIG โ”‚ VALUE โ”‚ SOURCE โ”‚
โ”œโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ค
โ”‚ apiEndpoint โ”‚ https://api-v2.zrok.io โ”‚ config โ”‚
โ”‚ defaultNamespace โ”‚ public โ”‚ binary โ”‚
โ”‚ headless โ”‚ false โ”‚ config โ”‚
โ”‚ superNetwork โ”‚ false โ”‚ config โ”‚
โ•ฐโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฏ
To create a local environment use the zrok2 enable command.
What could be the problem?
Same problem as here:
Hi @A_B Welcome to the community & thank you for alerting us of your issue. We had an incident today causing the above error. The system has been restored & everything should be functional now.
