403 Error 7 request per second
Hi Everyone! im running a little app with a self-hosted instance of zrok, (i am using a reserved share).
but every once in a while y get the 403 error and it blocks me for a couple of minutes.
is there a way to override this config?
i will appreciate any advice.
Edit:
i'm Aware that if i exceeed the 7 requests per second limit for over 5 minutes i will get this error, i was wondering if there's a way to bypass that.
Hi @jveliz-08 - there isn't a way to bypass that with a public share, however a private share does not go through the public frontend and is not subject to rate limiting.
oh that's interesting, thank you so much for the response!
