Hi, just upgraded my Proxmox PBS 3.4 to 4.0 which is Debian 13 Trixie but when I tried to install/upgrade ziti-edge-tunnel it fails with policykit-1 package?
Is there workaround or should I revert my upgrade ![]()
root@pbs2:~# UBUNTU_LTS=jammy
root@pbs2:~# echo "deb [signed-by=/usr/share/keyrings/openziti.gpg] https://packages.openziti.org/zitipax-openziti-deb-stable $UBUNTU_LTS main" | tee /etc/apt/sources.list.d/openziti.list >/dev/null
root@pbs2:~# apt update
Hit:1 http://security.debian.org trixie-security InRelease
Hit:2 http://ftp.fi.debian.org/debian trixie InRelease
Hit:3 http://download.proxmox.com/debian/pbs trixie InRelease
Hit:4 http://ftp.fi.debian.org/debian trixie-updates InRelease
Hit:5 https://packages.openziti.org/zitipax-openziti-deb-stable jammy InRelease
All packages are up to date.
root@pbs2:~# apt install ziti-edge-tunnel
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
ziti-edge-tunnel : Depends: policykit-1 but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. policykit-1:amd64=122-3 is not selected for install
2. policykit-1:amd64=122-3 is selected for install because:
1. ziti-edge-tunnel:amd64=1.7.6 is selected for install
2. ziti-edge-tunnel:amd64=1.7.6 Depends policykit-1
3. policykit-1:amd64 is available in version 122-3
