Docker Compose: no ziti edge list service-edge-router-policies configured
Not sure if this is expected, but when I setup a fresh Docker environment, there are no service edge router policies defined.
This is preventing the terminator from being hosted. I know I have some commands somewhere…
│ ID │ NAME │ SERVICE ROLES │ EDGE ROUTER ROLES │
The init container runs a small script that adds them.
Ahh.. I disabled that one.. I now know why it's needed :slight_smile:
I have a micro compute and need to be mindful of the resources I use.. so I disabled it to keep it really lean.
PS.. I found this command which should fix my problem.
ziti edge create service-edge-router-policy all-routers --edge-router-roles "#all" --service-roles "#all"
Bingo
ziti edge list terminators
│ ID                                   │ SERVICE          │ ROUTER           │ BINDING │ ADDRESS                              │ IDENTITY │ COST │ PRECEDENCE │ DYNAMIC COST │
│ d5c0df87-98f7-438e-b3de-8bede254263c │ private-postgres │ ziti-edge-router │ tunnel  │ d5c0df87-98f7-438e-b3de-8bede254263c │          │    0 │ default    │            0 │
Is there anything else this script does that I should be mindful of?
The 'init container' script? At this time, no. It's tiny. You can look at what it does here: https://github.com/openziti/ziti/blob/release-next/quickstart/docker/image/access-control.sh
#!/bin/bash
echo "*****************************************************"
#### Add service policies
# Allow all identities to use any edge router with the "public" attribute
ziti edge create edge-router-policy all-endpoints-public-routers --edge-router-roles "#public" --identity-roles "#all"
# Allow all edge-routers to access all services
ziti edge create service-edge-router-policy all-routers-all-services --edge-router-roles "#all" --service-roles "#all"
Thanks.. very helpful
