Dotzeet.key in the Quick Start example
I noticed the following key being generated in the Quick Start example
pki/instance-20220416-1603-intermediate/keys/instance-20220416-1603-dotzeet.key
Any tips on what its used for?
It appears to be related to the fabric identity… but are not sure how this relates back to the server / client keys.
not all quickstarts are as up-to-date as others. i suspect this is from a very old one. you could probably ignore this entirely.
where did you find that? it should probably get cleaned up
I used the following command
find . -depth -name "*.key"
./.ziti/quickstart/instance-20220416-1603/pki/instance-20220416-1603-intermediate/keys/instance-20220416-1603-dotzeet.key
Aaaaah. I had no clue that was still in there. thanks I’ll get it removed :slight_smile:
