Hi.
I am trying to automate the way an API consumer will get access to a dark service in NetFoundry, and part of that is to create the endpoint and enroll it.
I am checking this documentation: NetFoundry API Reference
But I see two things:
- When I tried:
curl ‘https://gateway.production.netfoundry.io/rest/v1/networks/a32b688b-d44-91e6-cd4e77dbb5ff/endpoints’ -i -X POST -H ‘Content-Type: application/json’ -H ‘Authorization: Bearer eyJraWQiOiJOaTREa3lTUWFRZjRicENzR3dTOFwvQlhwdjJJZVZBSlpKVUhUdHVLTNZPudIK1Mjehi1pZk5gvqPUAN7eeJu03CdsTX5GldF4IHV1G4C0FQ’ -d ‘{“name”:“Test Endpoint 01”,“endpointType”:“Device”,“geoRegionId”:“15095af7-689e-46c5-95bf-2772116a65c0”,“dataCenterId”:null,“haEndpointType”:“HAGW”,“o365BreakoutNextHopIp”:null,“source”:null,“syncId”:null,“syncResourceId”:null,“clientMfaEnable”:“NO”,“subscriptionId”:null,“countryId”:null,“sessionIdentityId”:null,“endpointGroupId”:null}’
HTTP/1.1 403 Forbidden
Date: Sat, 25 Mar 2023 18:56:48 GMT
Transfer-Encoding: chunked
Connection: keep-alive
Vary: Origin
Vary: Access-Control-Request-Method
Vary: Access-Control-Request-Headers
X-B3-TraceId: d50a480bd3f0a7d3
[{“logref”:“error”,“message”:“Client lacks authorization for the ‘create’ action on the ‘endpoint’ resource over the -null- resource path.”},{“logref”:“traceId”,“message”:“d50a480bd3f0a7d3”}]
I got that message. I am admin of this network and it seems I can’t create endpoints. I can create other things but no endpoints
I was also kind of confused since in the NetFoundry WEB UI the only two parameters that are asked when creating and endpoint are:
a) Endpoint Name
b) Attributes
- I found this: REST Examples -
Which was exactly what I was looking, but couldn’t found that resource in the API documentation. My questions is if that resource exist in the API documentation and if the answer is yes, where can I find it?
And my last question is:
Are those different resources to create endpoints? What is the difference between them?
I would like to create a device type of endpoint.
Thank u
