I want to write tests around how I'm using openziti.
eg)
create/detele identity
run a tunnel/router using an identity
The first kind of tests would only require making api calls to a ziti controller, so that makes sense.
But how should I go about testing creating tunnel using an identity. That would probably require creating an ubuntu instance that runs commands to start a tunnel servicesudo systemctl enable --now ziti-edge-tunnel.service etc..
Integration tests is a term that makes it sound like you're using an SDK? If you are using an SDK, I would make a client and a server and do a fully app-embedded test That's what I did when I made the ziti ops verify traffic subcommand.
If you specifically want to test ziti-edge-tunnel/tunnelers, then you'd make a service on "both sides" (bind/dial) and then make a simple request to it (could be raw bytes, could be http, whatever)
