Odd issue with FTPS over OpenZiti Overlay
Hello,
I'm setting up a cloud hosted webserver using HestiaCP, and it's using ProFTPD as the FTP server. I have the linux tunneler installed and working on that server, and ZDEW on my Windows 10 Machine, and they connect to the single router/controller I have hosted at the same site as my ZDEW. I have allowed port 21 and the passive ports (12000-12100) in Ziti intercept and enabled "forward port" on the host config. with the allowed port ranges there as well.
Using FTPS (Explicit over port 21) on the public IP (no Ziti) I can successfully authenticate and list directories and transfer files (passive mode), but when using OpenZiti which connects to 127.0.0.1 on the linux tunneller app, the connection succeeds but the passive mode sometimes fails (it's intermittant), as per FileZilla logs below. I notice the directory listing is also noticeably slower when using the overlay network.
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: MLSD
Error: GnuTLS error -15: An unexpected TLS packet was received.
Error: The data connection could not be established: ECONNABORTED - Connection aborted
I've been trying to use AI/Googling to resolve this but nothing seems to be working.
The ZDEW logs show the following:
[2025-04-10T20:44:00.419Z] INFO tunnel-cbs:ziti_dns.c:566 format_resp() found record[100.64.0.15] for query[1:cp.cloud.joshh.net]
[2025-04-10T20:44:02.166Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:34149 err=-14, terminating connection
[2025-04-10T20:44:03.687Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:34152 err=-14, terminating connection
[2025-04-10T20:44:06.548Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:34154 err=-14, terminating connection
[2025-04-10T20:44:06.567Z] WARN ziti-sdk:channel.c:553 dispatch_message() ch[0] received message without conn_id or for unknown connection ct[ED72] conn_id[11]
[2025-04-10T20:44:12.094Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:34160 err=-14, terminating connection
ProFTPD TLS logs:
2025-04-10 20:44:00,793 mod_tls/2.9.2[324797]: TLS/TLS-C requested, starting TLS handshake β”‚
2025-04-10 20:44:00,874 mod_tls/2.9.2[324797]: TLSv1.3 connection accepted, using cipher TLS_AES_128_GCM_SHA256 (12β”‚
8 bits) β”‚
2025-04-10 20:44:01,237 mod_tls/2.9.2[324797]: Protection set to Private β”‚
2025-04-10 20:44:02,396 mod_tls/2.9.2[324797]: SSL_shutdown error: SSL: β”‚
(1) error:0A000126:SSL routines::unexpected eof while reading β”‚
(2) error:0A000197:SSL routines::shutdown while in init β”‚
2025-04-10 20:44:02,843 mod_tls/2.9.2[324822]: TLS/TLS-C requested, starting TLS handshake β”‚
2025-04-10 20:44:02,950 mod_tls/2.9.2[324822]: TLSv1.3 connection accepted, using cipher TLS_AES_128_GCM_SHA256 (12β”‚
8 bits) β”‚
2025-04-10 20:44:03,297 mod_tls/2.9.2[324822]: Protection set to Private β”‚
2025-04-10 20:44:03,917 mod_tls/2.9.2[324822]: SSL_shutdown error: SSL: β”‚
2025-04-10 20:44:04,460 mod_tls/2.9.2[324823]: TLS/TLS-C requested, starting TLS handshake β”‚
2025-04-10 20:44:04,573 mod_tls/2.9.2[324823]: TLSv1.3 connection accepted, using cipher TLS_AES_128_GCM_SHA256 (12β”‚
8 bits) β”‚
2025-04-10 20:44:04,946 mod_tls/2.9.2[324823]: Protection set to Private β”‚
2025-04-10 20:44:32,631 mod_tls/2.9.2[324848]: TLS/TLS-C requested, starting TLS handshake β”‚
2025-04-10 20:44:32,741 mod_tls/2.9.2[324848]: TLSv1.3 connection accepted, using cipher TLS_AES_128_GCM_SHA256 (12β”‚
8 bits) β”‚
2025-04-10 20:44:33,040 mod_tls/2.9.2[324848]: Protection set to Private
Any ideas on what I could try or how to resolve this?
It's been quite a while since i tried FTP and I've never used FTPS. when i used ftp in pasv mode, the server would have an advertised address that's negotiated during the client connecting to the ftp server. This was generally an ip address that the client was supposed to use. If memory serves, that advertised ip had to be intercepted because that's how ftp works.
The best thing to do is to capture packets on both sides and then analyze those packets looking for timeouts or resets etc, indicating a problem, and something to look into.
I fear that's all I'll probably be able to offer right now. If anyone else has thoughts, hopefully they'll share. If anything else comes to mind I'll follow up.
From gpt
Client                                Server (FTP Passive Mode)
  |------- TCP 21 (control connection) ----->|
  |<------ 227 Entering Passive Mode --------|
  |        (e.g., 192,168,1,10,195,80)       |
  |------- TCP 50000 (data connection) ----->|  <- port 50000 = (195*256 + 80)
  |<-------- Data transfer or file ----------|
Control conn: client β†’ server on TCP 21
Server replies with IP:PORT for passive data conn
Client initiates separate TCP conn to that IP:PORT
Data flows over this new conn initiated by client
Hi @TheLumberjack,
Yes the FTP server does send a Passive IP to connect to (which is always wrong given how the Ziti tunnel works... I've tried putting an IP as an intercept and configur ProFTPD to send that IP and it does not seem to work correctly, either). But the good news is Filezilla is smart enough to attempt the data connection to the actual server IP rather than what it "reports" its IP to be, so we can ignore that for now. The control connection appears fine, this is specifically with the data connection.
I captured packets on my windows machine on the ziti tunnel and saw the connection error/RST ACK as per attached screenshot, and I noticed the ziti log aligns with the exact time of the FTPS reset - it appears it may be OpenZiti that is disconnecting if I read these logs right:
[2025-04-11T20:10:18.282Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:26186 err=-14, terminating connection
[2025-04-11T20:10:22.663Z] ERROR tunnel-sdk:tunnel_tcp.c:190 on_tcp_client_err() client=tcp:100.64.0.1:26190 err=-14, terminating connection
A rundown on the packet capture from Gemini AI:
  • Packet 148 (Client -> Server): TCP [SYN] - Client initiates connection to port 12001.
  • Packet 151 (Server -> Client): TCP [SYN, ACK] - Server acknowledges and sends its SYN.
  • Packet 152 (Client -> Server): TCP [ACK] - Client acknowledges. The TCP connection on port 12001 is successfully established. This confirms Ziti is correctly forwarding this passive port and ProFTPD (or the tunneler) initially accepted the connection. It rules out the idea that specific passive ports are simply blocked or not configured in Ziti.
  • Packet 153 (Client -> Server): TLSv1.2 Client Hello - The client starts the TLS handshake over the new data connection.
  • Packet 154 (Server -> Client): TCP [ACK] - The server acknowledges receiving the Client Hello packet.
  • Packet 155 (Server -> Client): TCP [RST, ACK] - This is the failure point. Immediately after acknowledging the Client Hello, the server side (100.64.0.15) sends a TCP Reset (RST) packet, abruptly killing the data connection.
I haven't captured from the server side yet, but now I'm suspecting it's the ziti tunnel going down/resetting. This does not seem to be a passive ip/port issue so much as the connection for data DOES happen, it's just immediately interrupted.
I tried to find relating Ziti Router logs as well... there are some errors reported here, but I'm not sure what they mean:
Apr 11 20:10:14 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 902 , connId: 256, newConnId: 0, circuitId: 9PpZNxlGaB","time":"2025-04-11T20:10:14.925Z"}
Apr 11 20:10:14 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 903 , replyTo: 902, connId: 256, newConnId: 439, success: true, msg: ","time":"2025-04-11T20:10:14.967Z"}
Apr 11 20:10:15 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 919 , connId: 327, newConnId: 0, circuitId: ct6WN4kdP","time":"2025-04-11T20:10:15.880Z"}
Apr 11 20:10:15 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 919 , replyTo: 919, connId: 327, newConnId: 440, success: true, msg: ","time":"2025-04-11T20:10:15.928Z"}
Apr 11 20:10:16 HOME2ZITI ziti[39384]: {"_context":"{c/ct6WN4kdP|@/ZXlr}\u003cInitiator\u003e","file":"github.com/openziti/ziti/router/xgress/xgress.go:571","func":"github.com/openziti/ziti/router/xgress.(*Xgress).flushSendThenClose.func1","level":"info","msg":"sending end of circuit payload","time":"2025-04-11T20:10:16.139Z"}
Apr 11 20:10:18 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 928 , connId: 327, newConnId: 0, circuitId: lsGZExlda","time":"2025-04-11T20:10:18.641Z"}
Apr 11 20:10:18 HOME2ZITI ziti[39384]: {"_context":"{c/9PpZNxlGaB|@/jvLp}\u003cInitiator\u003e","file":"github.com/openziti/ziti/router/xgress/xgress.go:571","func":"github.com/openziti/ziti/router/xgress.(*Xgress).flushSendThenClose.func1","level":"info","msg":"sending end of circuit payload","time":"2025-04-11T20:10:18.642Z"}
Apr 11 20:10:18 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 929 , replyTo: 928, connId: 327, newConnId: 441, success: true, msg: ","time":"2025-04-11T20:10:18.763Z"}
Apr 11 20:10:22 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 948 , connId: 256, newConnId: 0, circuitId: zw.WExldP","time":"2025-04-11T20:10:22.830Z"}
Apr 11 20:10:22 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 947 , replyTo: 948, connId: 256, newConnId: 442, success: true, msg: ","time":"2025-04-11T20:10:22.878Z"}
Apr 11 20:10:23 HOME2ZITI ziti[39384]: {"_context":"{c/zw.WExldP|@/6KDd}\u003cInitiator\u003e","file":"github.com/openziti/ziti/router/xgress/xgress.go:571","func":"github.com/openziti/ziti/router/xgress.(*Xgress).flushSendThenClose.func1","level":"info","msg":"sending end of circuit payload","time":"2025-04-11T20:10:23.023Z"}
Apr 11 20:10:42 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 954 , connId: 256, newConnId: 0, circuitId: xGPRNxkdP","time":"2025-04-11T20:10:42.837Z"}
Apr 11 20:10:43 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 950 , replyTo: 954, connId: 256, newConnId: 443, success: true, msg: ","time":"2025-04-11T20:10:43.134Z"}
Apr 11 20:10:44 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:159","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Tx","level":"info","msg":"sending dial: seq: 971 , connId: 266, newConnId: 0, circuitId: v-ORN4kda","time":"2025-04-11T20:10:44.010Z"}
Apr 11 20:10:44 HOME2ZITI ziti[39384]: {"file":"github.com/openziti/ziti/router/xgress_edge/accept.go:147","func":"github.com/openziti/ziti/router/xgress_edge.debugPeekHandler.Rx","level":"info","msg":"received dial result: seq: 966 , replyTo: 971, connId: 266, newConnId: 444, success: true, msg: ","time":"2025-04-11T20:10:44.056Z"}
Apr 11 20:10:44 HOME2ZITI ziti[39384]: {"_context":"{c/v-ORN4kda|@/bmeO}\u003cInitiator\u003e","file":"github.com/openziti/ziti/router/xgress/xgress.go:571","func":"github.com/openziti/ziti/router/xgress.(*Xgress).flushSendThenClose.func1","level":"info","msg":"sending end of circuit payload","time":"2025-04-11T20:10:44.362Z"}
Apr 11 20:10:44 HOME2ZITI ziti[39384]: {"_context":"{c/v-ORN4kda|@/zvxL}\u003cTerminator\u003e","file":"github.com/openziti/ziti/router/xgress/xgress.go:571","func":"github.com/openziti/ziti/router/xgress.(*Xgress).flushSendThenClose.func1","level":"info","msg":"sending end of circuit payload","time":"2025-04-11T20:10:44.363Z"}
Apr 11 20:10:44 HOME2ZITI ziti[39384]: {"_context":"{c/v-ORN4kda|@/zvxL}\u003cTerminator\u003e","circuitId":"v-ORN4kda","error":"cannot forward payload, no destination for circuit=v-ORN4kda src=zvxL dst=bmeO","file":"github.com/openziti/ziti/router/handler_xgress/receive.go:41","func":"github.com/openziti/ziti/router/handler_xgress.(*receiveHandler).HandleXgressReceive","level":"error","msg":"unable to forward payload","origin":1,"seq":5,"time":"2025-04-11T20:10:44.363Z"}
Apr 11 20:10:48 HOME2ZITI ziti[39384]: {"circuitCount":1,"ctrlId":"ctrl.ziti.domain.net","file":"github.com/openziti/ziti/router/forwarder/faulter.go:107","func":"github.com/openziti/ziti/router/forwarder.(*Faulter).run","level":"warning","msg":"reported forwarding faults","time":"2025-04-11T20:10:48.636Z"}
Edit: I should clarify this error does not happen every-time... it's seemingly random but happens often enough it's interupting the workflow.
In my experience, this has often been caused by the other side closing the connection immediately. For example, FTPS, is there some kind of certificate problem? It definitely would be a good idea to see if the traffic makes it to the other side via logs and/or tcpdump (wireshark) on the far side.
After various enhanced logging and packet captures, it does appear to be ProFTPd that is failing to conplete the TLS handshake and instead sends a TCP RST - though it's not clear why even with max logging with ProFTPD. It ONLY happens while connected to OpenZiti, so perhaps there is a latency issue that OpenSSL on the server side runs into because of traffic going over the overlay.
Packet capture server side on the lo (127.0.0.1) network during failure:
FileZilla max debug logging during failure:
Trace: CControlSocket::SendNextCommand()
Trace: CFtpRawTransferOpData::Send() in state 4
Trace: Binding data connection source IP to control connection source IP 100.64.0.1
Trace: tls_layer_impl::client_handshake()
Trace: Trying to resume existing TLS session.
Command: MLSD
Trace: tls_layer_impl::continue_handshake()
Trace: CTransferSocket::TransferEnd(3)
Trace: CFtpControlSocket::TransferEnd()
According to Gemini:
Therefore, the most consistent explanation across all evidence (both client/server captures and FileZilla logs) is:
  1. Client attempts data connection TLS handshake, explicitly trying session resumption.
  2. Server (ProFTPD) receives Client Hello.
  3. Server (ProFTPD) fails internally while processing the Client Hello / session resumption attempt under Ziti's latency conditions.
  4. Server (ProFTPD) sends TCP RST on the data channel almost immediately.
  5. Client's GnuTLS receives the RST unexpectedly -> reports GnuTLS error -15.
  6. FileZilla sees the TLS error -> reports ECONNABORTED.
  7. FileZilla/Client OS then cleans up the connections (sending FINs on control/data channels, etc., which might appear interleaved with the server RST/responses in captures depending on timing).
From the OpenZiti client side can you connect to the ProFTPd and return the certs and have a look at them? For example you should be able to use an openssl command to see the certs:
openssl s_client -connect proftpd.here:443 -showcerts </dev/null
Can you share that? My guess is that there's a SANS that is somehow being verified that's now failing because you're using 127.0.0.1... Something like that...
Hmmm so I was able to show it using:
openssl s_client -connect cp.cloud.domain.net:21 -showcerts -starttls ftp
I removed the tickets/cert and changed the domain for privacy but let me know if that's important, I can PM it:
Connecting to 100.64.0.14
CONNECTED(000001EC)
depth=0 CN=serv1web.cloud.domain.net
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
verify return:1
Certificate chain
0 s:CN=serv1web.cloud.domain.net
i:C=US, O=Let's Encrypt, CN=R11
a:PKEY: RSA, 4096 (bit); sigalg: sha256WithRSAEncryption
v:NotBefore: Apr 8 17:55:56 2025 GMT; NotAfter: Jul 7 17:55:55 2025 GMT
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
Server certificate
subject=CN=serv1web.cloud.domain.net
issuer=C=US, O=Let's Encrypt, CN=R11
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: rsa_pss_rsae_sha256
Peer Temp Key: X25519, 253 bits
SSL handshake has read 2456 bytes and written 1631 bytes
Verification error: unable to verify the first certificate
New, TLSv1.3, Cipher is TLS_AES_128_GCM_SHA256
Protocol: TLSv1.3
Server public key is 4096 bit
This TLS version forbids renegotiation.
No ALPN negotiated
Early data was not sent
Verify return code: 21 (unable to verify the first certificate)
220 FTP Server ready.
Post-Handshake New Session Ticket arrived:
SSL-Session:
Protocol : TLSv1.3
Cipher : TLS_AES_128_GCM_SHA256
Session-ID: 228B140AD8B7E533A3667BE7B5026D64ABD2137694797DD7D459B8D96487E1F7
Session-ID-ctx:
Resumption PSK: C638FAA3B7BD26C75E4B873F217BE356180084D34F09BE9F15DC96F0CB17CAB4
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 15840 (seconds)
TLS session ticket:
Start Time: 1744748319
Timeout   : 7200 (sec)
Extended master secret: no
Max Early Data: 0
read R BLOCK
SSL-Session:
Protocol : TLSv1.3
Session-ID: B81572D5B254C9EB77861FAC6371A72CACBDF830C41A4F56CCEDBF655AF3FC71
Session-ID-ctx:
Resumption PSK: 1860E5A217EA4D385765C746126EB2DD30F4EBBF77F15DDC5578EA5AAFA6F065
PSK identity: None
SRP username: None
TLS session ticket:
Max Early Data: 0
read R BLOCK
can you take off the -starttls ftp bits too? I wanted to see the openssl s_client -connect output with the ftp stuffs...
At this point, I'm pretty sure this is just an overall TLS-related issue and not an OpenZiti issue. Still, it can be complex to sort out tls issues so I'm happy to try to help out a bit more...
In the past, was this FTPS instance on a VPN or was it on the open internet by chance?
Oh, sorry, yes here it is:
CONNECTED(000001E8)
24810000:error:0A00010B:SSL routines:tls_validate_record_header:wrong version number:..\ssl\record\methods\tlsany_meth.c:85:
no peer certificate available
Negotiated TLS1.3 group:
SSL handshake has read 5 bytes and written 1557 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Protocol: TLSv1.3
No ALPN negotiated
Verify return code: 0 (ok)
Well, it's a new VPS hosted in the cloud running Ubuntu 24.04 LTS, and I installed HestiaCP (control panel) on it which sets up the TLS certs for FTPS automatically and it expects to serve it publicly, but since ProFTPD listens on all interfaces, I just disabled the firewall access to Port 21, and the passive ports and installed OpenZiti to connect to it through 127.0.0.1 to make it "dark".
I would agree that it is a TLS issue, however without OpenZiti in the mix (aka if I connected publicly) then I never see this error, but connect with OpenZiti and this error appears every so often (that's the strange part, it doesn't ALWAYS fail).
Oh man. Darn, I missed that/forgot that... I'm sorry! So it sometimes works and sometimes fails. Is it possible that the url is overlapping a public url or did you give it a whole new domain name/intercept?
Also, I know you're using ZDEW but the FTPS client, is it linux / WSL or is it windows native?
Correct
Yes, it is - I did verify that it's resolving to the Ziti IP rather than the public IP of the server, though (via ping and looking at the name resolution). The intercept passes through the port (since I don't know what passive port each client will use).
It's running directly in Windows 10, not using the linux subsystem or any abstraction layers. It's FileZilla (3.68.1)
And going back to that packet capture. Can you capture an interaction when it succeeds and one when it fails? I looked at it again with a closer set of eyes...
I notice a bunchof non-printable chars. It's possible the stream is somehow getting messed up, which ends up leading to the "500" error and the "not understood" response which happens just before the reset.
So it seems to me that the server gets a command, it doesn't understand the command, and RST's.
That made me look at the Request when i noticed the non-printables. Those might be expected and just fine. That's why I'd like to compare a 'clean' request' to one that fails. Ideally the exact same request where one worked, one failed...
Thanks for sticking with me through this, there's definitely something interesting going on
Failure:
Success (same session/capture... just reconnecting a few times until it works):
Yeah, it's interesting. In the success path you see the SYN, SYN,ACK, and a Request: AUTH TLS and it succeeds. On the fail path, the Request: looks ok but the "AUTH TLS" gets all jumbly...
Hate to ask but can you also capture on the client side before it goes into the tunneler? It'd confirm that the request going in, is not what comes out the far end.
Oh and if you could confirm, what version of ZDEW is this?
I think you mean on the Ziti tunnel, given the ethernet adapter would just show encrypted packets for ziti, correct? If so, here you go - I'm unsure as to when exactly the failed comms start - you can see the end of the succesful one with AUTH TLS succesful (it succeeded before the failed test)
As for the ZDEW version, I was using the last published version and earlier today before testing I upgraded to the one you just published (2.6.4.0)
No worries at all, if we found a bug and it gets fixed, that's a win!
@007bond007 What is the version of linux tunnel you are running? Also I am assuming you are running x64 version of Ubuntu 24.04 right?
1.5.4
Yes:
Distributor ID: Ubuntu
Description: Ubuntu 24.04.2 LTS
Release: 24.04
Codename: noble
x86_64
@007bond007
Is it possible for you to run this from your window, or wsl?:
openssl s_client -connect <address?>:21 -starttls ftp
I believe this should give you same issue with filezilla if the issue with with ziti.
At the same time, if you can capture the output from your server, that would help.
sudo ssldump -d -k -i lo port 21
I tried to download filezilla from their website, but the anti-virus flag the download as virus.
