Openzili client not online
Dear members
I deployed openziti controller and router, but when enroll device to controller, status on client is available , but on controller, it’s offline status
Is there any one met this case
Hi @hacker05 ,
I've encountered this exact issue before — the problem is likely a missing Edge Router Policy.
Even after successfully deploying and enrolling your Edge Router, you need to explicitly create a policy that allows your devices to connect through it. Without this policy, the devices cannot connect to the router.
Go to Policies → Router Policies in your controller's admin UI and check if you have a policy linking your identities (or #all) to your Edge Router (or #all). If that policy doesn't exist, create it.
Could you share a screenshot of your current Router Policies configuration? That would help confirm whether this is the root cause.
Hi @hacker05, welcome to the community and to OpenZiti!
As @stalow said, a missing policy can certainly cause this problem. The ziti CLI has a command that will help you verify if the network is setup correctly by making a client and server identity and then starting a test server to pass traffic from the client to the server. This command is:
ziti ops verify traffic
Run this ziti command from the client machine (or some other machine that isn't the controller or a router). You should see stuff like:
INFO  successfully bound service: ...
INFO  found terminator for service: ...
INFO  successfully dialed service: ...
INFO  traffic test successfully detected
INFO  client complete
Can you run that and capture what you see? Another discourse post where I mention this sort of troubleshooting is over at Windows Desktop App Error - #15 by TheLumberjack -- have a look at that too and see if it helps
