How can i build an OpenZiti Controller
Hi @preetmehar , welcome to the community! You want to build the code or deploy a controller? If you want to try setting up an overlay network you should start with one of the quickstarts that works for you. Start by checking out the docs over at Start Cooking With Ziti | Ziti
If you’re looking to build and compile the controller you’ll need to be familiar with go. You can build the OpenZiti/ziti project, found over on GitHub at GitHub - openziti/ziti: The parent project for OpenZiti. Here you will find the executables for a fully zero trust, application embedded, programmable network
