OpenZiti MFA via Oracle Mobile Authenticator
Quick check into to see if OpenZiti supports Oracle Mobile Authenticator to generate MFA.
I have not really explore this to date… and thought to ask if its supported.
One of the advantages of using OpenZiti that I am now seeing is that MFA is integrated into the network layer… as opposed to the application layer… making it a lot easier to integrate MFA without the need for any code changes.
Does this make sense?
It appears that Oracle mobile authenticator is a standard totp type of application, same as Google’s, Microsoft’s etc. You’d just have to take a pic of the jwt or enter the secret manually.
You should be able to use it, sure. I don’t know if there’s anything extra or special about oracle’s variant, but it seems to me after looking at it for a few minutes it’d be fine.
