Android Tunneler - Can not enable MFA
I don't see any options to enable MFA on android tunneler (Ziti Mobile Edge). App version is 0.8.1 and has no update since Aug 2023.
Hi @kaiba_seto2004, the general consensus during MFA implementation was that it seemed unnecessary to implement for mobile devices due to the fact that if you're interactive on the device, you'll most likely have access to the TOTP generator on that device, which is the most likely place for it to be and as such, we did not implement MFA on Desktop Edge for Mobile.
Hi @TheLumberjack
I got a service which required MFA posture check. This will prevent android users from authenticating but ios users, because ios has this MFA function in the app.
Yes, that would be a problem. At this time when setting up MFA, we recommend it apply to Mac/Windows/Linux, not "SDK-based apps", android, iOS.
Thank you very much sir!
I disagree as that is not completely true.
Android do support for many platforms and use cases such as tablets, kiosk, TV, Electronic Data Capture (EDC), etc you named it ... and these use cases showed those device are not trusted devices, where MFA is on trusted devices.
Hence, in android world, the device need to be MFA authenticated and TOTP generator on another trusted device is very common.
