My netwok consists of a private router, a public router hosted by netfoundry and various endpoints. My internet connection is satellite with latency of about 700ms. Everything was working well up until about a week ago. I lost connection between endpoints both when my laptop was on the local network and on a remote network. The netfoundry console is showing all endpoints online. I’m seeing errors in my private router - looks like its not connecting to the public router:
May 23 09:16:48 antlet19 ziti[11151]: {"_context":"tls:1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io:6262","error":"EOF","file":"github.com/openziti/channel/v2@v2.0.27/classic_dialer.go:69","func":"github.com/openziti/channel/v2.(*classicDialer).Create","level":"warning","msg":"error initiating channel with hello","time":"2023-05-23T09:16:48.008Z"}
May 23 09:16:48 antlet19 ziti[11151]: {"file":"github.com/openziti/channel/v2@v2.0.27/message.go:649","func":"github.com/openziti/channel/v2.getRetryVersionFor","level":"info","msg":"defaulting to version 2","time":"2023-05-23T09:16:48.008Z"}
May 23 09:16:48 antlet19 ziti[11151]: {"_context":"tls:1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io:6262","file":"github.com/openziti/channel/v2@v2.0.27/classic_dialer.go:73","func":"github.com/openziti/channel/v2.(*classicDialer).Create","level":"warning","msg":"Retrying dial with protocol version 2","time":"2023-05-23T09:16:48.008Z"}
May 23 09:16:49 antlet19 ziti[11151]: {"_channels":["link","linkDialer"],"address":"tls:1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io:6262","error":"error dialing outgoing link [l/3HDIaAoRqUbV9ZEQKOtDyn]: error dialing payload channel for [l/3HDIaAoRqUbV9ZEQKOtDyn]: EOF","file":"github.com/openziti/fabric@v0.22.24/router/handler_ctrl/dial.go:109","func":"github.com/openziti/fabric/router/handler_ctrl.(*dialHandler).handle","level":"error","linkId":"3HDIaAoRqUbV9ZEQKOtDyn","linkProtocol":"tls","msg":"link dialing failed","routerId":"gBxvTOQ9cd","routerVersion":"v0.27.5","time":"2023-05-23T09:16:49.716Z"}
I’m also seeing errors in the laptop log, but these may be the result of the private router being offline:
May 23 07:16:51 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 124761.389] ERROR ziti-sdk:ziti_ctrl.c:155 ctrl_resp_cb() ctrl[1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io] request failed: -103(software caused connection abort)
May 23 07:16:51 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 124761.389] ERROR ziti-sdk:ziti.c:1052 update_services() ztx[0] failed to get service updates err[CONTROLLER_UNAVAILABLE/software caused connection abort] from ctrl[https://1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io:443]
May 23 07:16:51 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 124761.389] WARN tunnel-cbs:ziti_tunnel_ctrl.c:739 on_ziti_event() ziti_ctx controller connections failed: Ziti Controller is not available
May 23 07:16:51 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 124761.389] ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:1199 on_event() ztx[/opt/openziti/etc/identities/laptop.json] failed to connect to controller due to Ziti Controller is not available
May 23 08:05:03 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 127653.568] ERROR ziti-sdk:ziti_ctrl.c:155 ctrl_resp_cb() ctrl[1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io] request failed: -104(connection reset by peer)
May 23 08:05:03 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 127653.568] ERROR ziti-sdk:ziti.c:1052 update_services() ztx[0] failed to get service updates err[CONTROLLER_UNAVAILABLE/connection reset by peer] from ctrl[https://1cbcdfd4-c7ac-4be9-8f2e-1075845c774c.production.netfoundry.io:443]
May 23 08:05:03 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 127653.568] WARN tunnel-cbs:ziti_tunnel_ctrl.c:739 on_ziti_event() ziti_ctx controller connections failed: Ziti Controller is not available
May 23 08:05:03 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 127653.568] ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:1199 on_event() ztx[/opt/openziti/etc/identities/laptop.json] failed to connect to controller due to Ziti Controller is not available
May 23 08:05:07 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 127658.111] ERROR ziti-sdk:channel.c:489 dispatch_message() ch[1] received message without conn_id or for unknown connection ct[ED71] conn_id[312]
May 23 08:22:09 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 128679.124] WARN ziti-sdk:connect.c:351 connect_timeout() conn[0.313/Connecting] failed to establish connection in 10000ms on ch[1]
May 23 08:22:09 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 128679.124] ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: Operation did not complete in time
May 23 08:22:12 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 128683.076] ERROR ziti-sdk:channel.c:467 dispatch_message() ch[1] could not find waiter for reply_to = 146
May 23 08:22:12 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 128683.076] ERROR ziti-sdk:channel.c:489 dispatch_message() ch[1] received message without conn_id or for unknown connection ct[ED70] conn_id[313]
May 23 08:22:12 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 128683.076] ERROR ziti-sdk:channel.c:489 dispatch_message() ch[1] received message without conn_id or for unknown connection ct[ED72] conn_id[313]
May 23 08:33:18 ThinkPad-SL510 ziti-edge-tunnel[1611]: (1611)[ 129348.831] ERROR ziti-sdk:channel.c:489 dispatch_message() ch[1] received message without conn_id or for unknown connection ct[ED71] conn_id[318]
Suggestions on further troubleshooting would be welcome.
