New role attributes not added when creating a simple identity but it can be added after editing the identity. Once edited, then it appears in Simple Identity but writing new doesn't appears in Roles section.
Thank you
Thank you
Are you using ZAC or ziti CLI? Can you provide steps to reproduce? I'm not able to understand the flow you're following. If you could provide step-by-step instructions (or a video/gif) that'd be helpful.
@jeremy.tellier, can you please reproduce and verify?
Update:
Role Attributes not adding in Service as well.
No, I cannot reproduce.
@kashif - You have to actually select a valid role attribute from the list for the Identity and Service Role Attributes are not exposed in the simple add, the selections add to the policies. I may add this though but it is something I would just use the regular service form for.
So if you want to use that form to "Add a New Role Attribute", hit "Enter" when you freeform type.
Thank you for your clarification and guidance. Service form is better in this case.
In the case I don't need the role/role attributes. How can I then delete it because there's just view option available in Manage Attributes (attribute explorer).
Thank you
