.service files not generated using expressInstall
Tested today the Host OpenZiti Anywhere | OpenZiti, everything worked fine until the Host OpenZiti Anywhere | OpenZiti section:
sudo cp "${ZITI_HOME}/${ZITI_CTRL_NAME}.service" /etc/systemd/system/ziti-controller.service
sudo cp "${ZITI_HOME}/${ZITI_ROUTER_NAME}.service" /etc/systemd/system/ziti-router.service
But there are no .service files generated anywhere so the commands fails.
Hi @Zincr0, welcome to the forum and to OpenZiti!
Really? Strange. Did you run the two commands to generate them?
createControllerSystemdFile
createRouterSystemdFile "${ZITI_ROUTER_NAME}"
what output did that give you? can you share any errors?
It was a typo, nvm, fixed
