Hi all!
I'm confused about what the difference is between zrok frontdoor and just running a reserved http share that gets started by the zrok agent automatically and runs all the time. I've read all the documentation I can find, and I can see that frontdoor seems to do a couple of things:
- That it is a "heavy-duty" front door to an app. But I see no description of what this actually means practically or technically.
- That it can restrict access based on OAuth to Google or Github (vs. normal shares which afaik can only restrict access to private shares via zrok.io accounts?)
- That it is packaged as a separate app/package/docker image
- That is designed to be run by systemd on boot (vs. zrok agent which wants to run as a user unit, I believe, so will only be up while the user is logged in?)
Am I understanding this correctly? Am I missing key things, or misunderstanding any of the things I've said above?
Hi and welcome, @eletari .
You're correct. zrok frontdoor is a way of using zrok with NetFoundry's zrok.io service, which provides a robust frontend with automatic TLS for your public shares.
The zrok frontdoor guide needs a refresh to help with using the new zrok agent. I've been enjoying using it myself, so here's a quick overview.
- Set up the zrok agent as an always-on service with your Windows or Linux user account. Remember to run
zrok enable with your zrok account token to create a zrok environment on the device owned by your login.
- After the agent is running (
zrok agent status), optionally enroll the agent so you can control it remotely through the console.
- Create a public share with the console if you enabled "remoting," or run the commands locally if not remoting (
zrok reserve public; zrok share reserved).
- Now your web thing has a strong front door!
Here's a Docker Compose sample I've been playing with on Linux based on the Docker guide. You have to set env var UID on some distributions to id -u. I don't know if this will work with Docker Desktop on Win/Mac because those use a virtual machine to provide the container runtime, so you'd have to confirm the bind volume path and permissions, if it's even possible to mount a Win/Mac host dir in the VM.
The main difference with using the agent this way is that it re-uses the zrok environment created by your login user instead of creating a separate zrok environment for the agent, but I plan to eventually document doing it both ways.
services:
zrok-agent:
image: docker.io/openziti/zrok
restart: unless-stopped
entrypoint: bash -c "rm -f /mnt/.zrok/agent.socket && exec \"$@\""
command: -- zrok agent start
user: "${UID}"
volumes:
- ${HOME}/.zrok:/home/ziggy/.zrok
Controlling access to public shares with Google or GitHub OAuth is a feature of zrok, and it's preconfigured for you when you use NetFoundry's zrok.io service. The usage hints for adding OAuth to a zrok public share are all the way at the bottom of this page: OAuth Public Frontend Configuration | zrok
Here's what we have available:
- Linux
zrok-share.service - runs any one share backend as a system service with a separate, dedicated zrok environment (documented as "zrok frontdoor")
zrok-agent.service - runs many share backends as a user service, sharing the login user's zrok environment
- Docker
zrok-share service - runs any one share backend as a Docker service with a separate, dedicated zrok environment
zrok-agent service - runs many share backends, sharing the login user's zrok environment
- Windows
Got it, thanks! I was getting some "these docs seem out of date" vibes, sounds like it's basically all there in the main package at this point. Much appreciation for the answer!
