I am using ZAC… which is really cool… and wanted to edit an identity… I have seen this before… but the edit button was not showing up
Then I widened the screen and the edit “…” section appeared
It would be nice if you did not need to adjust the screen size for the edit button to appear.
I also just realised that ZAC shows the names of the users..
this only appeared after I realised that there was a hidden field.. that could be stretched..
if you notice in the earlier screen captures.. the name field is almost hidden
If you get even smaller you kick into mobile mode and they reappear. If you are in between sizes and a table cell takes up too much space. You can resize the table with the header drag lines and you can show the three dots again.
