Is it possible to connect Ziti Desktop Edge for Windows with Azure AD (Entra MFA) or
Authentication via Azure AD (Entra MFA)?
Thank you for your great product and your work.
We are currently working on implementing oidc support for tunnelers. Curt did some work to ensure browzer worked with entra, so that's already in place.
Oidc support in ZDEW is expected in a few weeks, when it comes out it'll likely go into the ZDEW beta stream for a while, then on to latest and finally into stable.
Thank you very much.
Das wird großartig
