Is there a setting to allow ziti to automatically connect on reboot/following system updates?
I believe @NicFragale has helped folks do this using the scutil --nc start "Ziti Desktop Edge" on startup on macOs. I'm not sure if he has something similar for iOS.
Possibly using "Set VPN" as part of a Shortcuts workflow on iOS?
I had the thought to set Ziti Mobile Edge to "On Demand", however there is no toggle for it in the settings ![]()
Yeah - I was trying to come up with “in the meantime” approaches. Adding on-demand is something we’ve discussed but don’t have on the short term roadmap
