Are the zrok compose config in the repo production ready, I don't have a lot experience with k8s deployments, and want to setup a zrok instance for low production load.
I'm asking because I noticed that this config is using openziti quick-start.
thanks
Hi @mbenachour,
Yeah, zrok's doc was first put out when we only had quickstarts for people to look at. Plenty of people used those quickstarts for their own production use cases. As long as you're backing up the database/config/pki and as long as you're running the controller as a systemd service, I think you'll be fine.
If you haven't done those things, then you might consider implementing that sort of backup first. i don't think zrok has a similar guide yet for backing up though, we'll have to get that on the list of doc to produce.
Plenty of people are using zrok for all sorts of things right now too, so I think it's ready. Also, the free NaaS https://zrok.io shares lots of things/data every day. 100's of gigs a day more or less.
