Zrok enable does not work
I can not enable environment.
zrok version
v1.0.3 [a0fc822a]
zrok enable token
⣟  the zrok service returned an error: Post "https://domain.name:port/api/v1/enable": stream error: stream ID 1; IN
zrok controller's log
May 02 15:08:54  zrok[183387]: {"level":"info","ts":1746198534.8382885,"msg":"http2: panic serving 81.222.178.253:40055: json: unsupported type: func(*http.Request) (*url.URL, error)\ngoroutine 20066 [running]:\nnet/http.(*http2serverConn).runHandler.func1()\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/h2_bundle.go:6242 +0x145\npanic({0x248c340?, 0xc001891a30?})\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/runtime/panic.go:785 +0x132\ngithub.com/openziti/zrok/controller.(*enableHandler).Handle(0x55a1ae0, {0xc0011283c0, {{0xc000d61db0, 0x7}, {0xc0008ea5f0, 0x42}}}, 0xc00035a200)\n\t/__w/zrok/zrok/controller/enable.go:91 +0xe15\ngithub.com/openziti/zrok/rest_server_zrok/operations/environment.(*Enable).ServeHTTP(0xc001d0b620, {0x3f69168, 0xc0009f7000}, 0xc0011283c0)\n\t/__w/zrok/zrok/rest_server_zrok/operations/environment/enable.go:71 +0x290\ngithub.com/go-openapi/runtime/middleware.(*Context).RoutesHandler.NewOperationExecutor.func1({0x3f69168, 0xc0009f7000}, 0xc0011283c0)\n\t/github/home/go/pkg/mod/github.com/go-openapi/runtime@v0.28.0/middleware/operation.go:28 +0x53\nnet/http.HandlerFunc.ServeHTTP(0xc000310140?, {0x3f69168?, 0xc0009f7000?}, 0xc001dc7950?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:2220 +0x29\ngithub.com/go-openapi/runtime/middleware.NewRouter.func1({0x3f69168, 0xc0009f7000}, 0xc001128280)\n\t/github/home/go/pkg/mod/github.com/go-openapi/runtime@v0.28.0/middleware/router.go:80 +0x257\nnet/http.HandlerFunc.ServeHTTP(0xc000d61ba0?, {0x3f69168?, 0xc0009f7000?}, 0x2c?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:2220 +0x29\ngithub.com/go-openapi/runtime/middleware.SwaggerUI.serveUI.func1({0x3f69168, 0xc0009f7000}, 0xc001128280)\n\t/github/home/go/pkg/mod/github.com/go-openapi/runtime@v0.28.0/middleware/ui_options.go:164 +0xda\nnet/http.HandlerFunc.ServeHTTP(0xc000d61ba0?, {0x3f69168?, 0xc0009f7000?}, 0x442e97?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:2220 +0x29\ngithub.com/go-openapi/runtime/middleware.Spec.func1({0x3f69168, 0xc0009f7000}, 0xc001128280)\n\t/github/home/go/pkg/mod/github.com/go-openapi/runtime@v0.28.0/middleware/spec.go:72 +0x1a8\nnet/http.HandlerFunc.ServeHTTP(0xc000d61ba0?, {0x3f69168?, 0xc0009f7000?}, 0xc00039d03a?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:2220 +0x29\ngithub.com/openziti/zrok/rest_server_zrok.configureAPI.setupGlobalMiddleware.Middleware.func5({0x3f69168, 0xc0009f7000}, 0xc001128280)\n\t/__w/zrok/zrok/ui/middleware.go:14 +0x3c2\nnet/http.HandlerFunc.ServeHTTP(0x18?, {0x3f69168?, 0xc0009f7000?}, 0xc0016d5f80?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:2220 +0x29\nnet/http.serverHandler.ServeHTTP({0xc0011169e0?}, {0x3f69168?, 0xc0009f7000?}, 0xc00224de00?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:3210 +0x8e\nnet/http.initALPNRequest.ServeHTTP({{0x3f72c78?, 0xc001510a20?}, 0xc001116708?, {0xc001fdb2c0?}}, {0x3f69168, 0xc0009f7000}, 0xc001128280)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/server.go:3819 +0x231\nnet/http.(*http2serverConn).runHandler(0x44f57b?, 0xc00224dfd0?, 0x7c95e5?, 0xc0007916c0?)\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/h2_bundle.go:6249 +0xf5\ncreated by net/http.(*http2serverConn).scheduleHandler in goroutine 20056\n\t/github/home/go/pkg/mod/golang.org/toolchain@v0.0.1-go1.23.2.linux-amd64/src/net/http/h2_bundle.go:6183 +0x21d"}
We're already working on it. v1.0.4 will be released today.
In the meantime, stay on v1.0.2.
v1.0.4 has been released, which corrects the issue.
In release notes you say that openziti/ziti has been updated to v1.6.0.
The last version available in debian repository is ziti v1.5.4.
Is it safe to stay on ziti v1.5.4 ?
Yes. The ziti version included in the zrok container image was updated, but it doesn't depend on that specific version.
Edit: Same answer but for a different reason now that I see you're referring to this announcement about an updated go module import in zrok. I don't expect it introduces any dependency in that version of ziti controller or router.
GitHub - openziti/ziti: The parent project for OpenZiti. Here you will find the executables for a fully zero trust, application embedded, programmable network @OpenZiti has been updated to v1.6.0
Yes. You're free to use OpenZiti 1.5.4.
