Zrok2 connecting to self-hosted apiEndpoint issue
I’m trying to migrate to zrok2, I have installed zrok2 binary and set my endpoint to my zrok domain, but when trying to enable zrok2 environment I get this:
there was a problem enabling your environment!
you are trying to use the zrok service at: https://zrok.mydomain.io
$ zrok2 config set apiEndpoint
[ERROR]: error creating service client (client version error accessing api endpoint 'https://zrok.mydomain.io': [POST /clientVersionCheck] clientVersionCheck (status 202): {}: [POST /clientVersionCheck] clientVersionCheck (status 202): {})
ofc I masked original domain, but original one does available from browser and zrok v1 works with it perfectly. What may be the problem?
Are you running a zrok2 controller? The controller API is different for v2.
No, I guess it is the problem, thank you!
