I got through the Initial Setup and did some playing around with services. and I wanted to take a deep dive into the admin console, install was easy but after connecting to the webpage I input what is in the documentation to connect to the edge controller and I get an error that says edge controller not online
oh - it’s entirely local. I didn’t realize it was a “host it local (no docker)”. We’ll have to dig in a tiny bit. You’re running this in linux, right? Can you access https://localhost:1280 ? does that return a response?
probably selinux i would say, if you turn it off temporarily via setenforce does it work?
I got it working on almalinux 9, with selinux on, but had to add a couple of custom modules to work.
Very strange. After some fumbling around on my side with RHEL (signing up for a RedHat account, downloading 7.9, running it in a virtual machine, using firewall-cmd to open the ports), it ended up working for me properly.
It might be worthwhile to stop the ZAC and run it in debug mode. Instead of using the systemd file (created if you just run the install steps), maybe you can try to stop that service (systemctl stop ziti-console) and then run it from the command line node server.js debug, maybe some extra logging is shown in the console?
I think I may have just found out why when I go to check the status of the controller nothing appears and when I try and start the controller it does not recognized the command
That's really strange. Could it be something silly where /etc/hosts doesn't have localhost declared and somehow the browser is doing the translation from localhost to 127.0.0.1?
Can you login with 127.0.0.1? As in using this for the controller url https://127.0.0.1:1280
