Hi Team, I created a virtual android phone via android studio, and I wanted to create a tunneler between the phone and the edge router I have set up. Is this possible without downloading the Ziti Mobile Edge for Android?
If you create a full android application with an OpenZiti SDK inside, you do not need to download Ziti Mobile Edge for Android. Your application will connect to all edge routers it’s permitted to connect to when it comes online.
I see. I want the phone to connect to a web app I developed on another server only through the Ziti Overlay. I don’t have any android app developed on the phone. In this case I will need to download the Ziti Mobile Edge right?
If you are not creating your own app, then yes, that’s when you would download, install and use the ZMEA. You got it.
