Android - Tunneler and Battery Usage
Hi there, I’ve noticed my phone getting pretty hot lately, and the battery usage being pretty bad… looks like ziti has a few issues on my phone with Android
Any thoughts on things to debug/check?
Thanks
first, please submit feedback via the app.
when you notice that, do you use WiFI or cellular network?
@ekoby no worries, have submitted the feedback. This is on wifi…
However I think I have found the culprit, I had an identity that was connecting to a trial instance of netfoundry ages ago, so it was probably constantly trying to connect. Todays usage is much better so far with ziti being way down the list, so I think this is fine now after removing that identity.
Thanks
