Same as topic #6102, cannot delete stuck environment 500 throughout.
Please delete: grifqialdi@*******.**.localdomain / EnvZId ekdXFXicjK (api-v2.zrok.io, created 2026-09-14, IP 193.204.135.241)
Symptoms: POST /share, /disable, /enable all 500 (even ephemeral/private + fresh enable token). zrok disable cleaned local but server orphan remains. Web UI delete also fails.
I’m facing a similar issue: the root@fb69af4ef628 and root@d0dc3a3ed204 environments have hung and won't delete. Everything was working fine yesterday, but today they’ve hung again.
Hi. Just following up here too. I made this post on the pinned topic but just FYI here to make sure I cover all the bases... [duplicating the summary of that post here follows]
If you had stuck sessions that cannot be deleted, I'm told you should now be able to delete them on your own again. I don't have any I can test myself personally but if someone does and if they could post a follow-up here with success (or failure but let's hope not) that would be appreciated.
Thanks again for reporting the issues and bearing with us while we make zrok better!
