Stuck environment and share throwing 500 error on web console
Mesaj:
Hello,
I am unable to delete a stuck environment and its associated share from my hosted zrok account. The web console throws a 500 internal server error ("An error occurred releasing your environment").
The stuck environment details:
  • Environment ID: 9F22gJ6cI
  • Stuck Share Host Info: Host shell; localhost; android; aarch64
Could an administrator please manually prune/delete this orphaned environment and its shares from the backend database? Thank you!
Just following up here to let you know in case you haven't seen.. Please follow that thread for updates
Hi. Just following up here too. I made this post on the pinned topic but just FYI here to make sure I cover all the bases... [duplicating the summary of that post here follows]
If you had stuck sessions that cannot be deleted, I'm told you should now be able to delete them on your own again. I don't have any I can test myself personally but if someone does and if they could post a follow-up here with success (or failure but let's hope not) that would be appreciated.
Thanks again for reporting the issues and bearing with us while we make zrok better!
