It seems I have a max of two reserved shares at one time both running with udptunnel backend. This two only seem to be able to run for about 30 mins before ssh times out and the tunnel closes. When I connect back to my AWS server, history is there, I can just hit up on the arrow key and enter to open the tunnel back up. I check server logs and there has been no restart and as far as I can tell, no migration. It may be a power shell setting I’m unaware of? I’m using cmd to ssh into my server with window’s ssh utility. That may also be my issue. Any tips? Also, when I try to make a third share, it says I need to enable the zrok environment, is this an intended feature or a glitch, or am I doing something wrong?
Hi @0024logan, bear with us as it's the holiday season. Someone will be able to answer this question likely next week. Cheers
It sounds like you are hitting the limit for the number of environments you can enable for your current zrok plan (which is 2 on the free plan). Not sure on the 30-minute timeout, but 30 minute seems suspiciously like it might be an idle timeout for *something.
