Named public shares fail to recover after zrok2 agent restart (409 shareConflict)
Hi zrok team,
I’m reporting a recurring problem with named public shares after restarting the zrok2 agent. The agent starts, but a public share can remain in retrying because the previous share still holds its reserved name on the controller. Every retry then fails with 409 shareConflict, and the public URL stays unavailable.
Here is a step-by-step example of the failure:
  1. Start a local HTTP service at http://127.0.0.1:8080.
  2. Reserve a name: zrok2 create name restart-repro.
  3. Start zrok2 agent start under a process supervisor.
  4. Register the share: zrok2 share public http://127.0.0.1:8080 --name-selection public:restart-repro --open --headless --force-agent.
  5. Confirm that the URL works and zrok2 agent status shows the share as active.
  6. Restart the agent. The failure occurs when shutdown does not finish cleanly, including a supervisor timeout or an abrupt host shutdown.
  7. After the agent starts again, zrok2 agent status shows the share as retrying, while zrok2 list shares still shows the previous share holding the name. The agent repeatedly receives: 409 shareConflict: name 'restart-repro' in namespace 'public' is already in use by another share.
Expected: The agent restores the public URL automatically, either by reattaching to the existing share or safely reconciling the stale controller record.
Actual: Retries cannot resolve the conflict. Recovery requires manually deleting the previous share and letting the agent create another one. Deleting and recreating every public share after an agent restart is unacceptable for endpoints that are expected to remain available.
My current setup is macOS, zrok2 v2.0.8, with the agent managed by PM2. I have experienced this 409 during restarts, but have not intentionally repeated the restart on the current build because it would interrupt active public shares. The behavior also matches GitHub issue #1259 and this Discourse report.
Is reliable reattachment of named public shares supported today? If not, is there a fix planned? Please also provide a supported recovery procedure that does not require deleting every share in the account on each startup.
I would bet your process supervisor isn't sending SIGTERM or SIGINT to the agent at shutdown time. If it's sending SIGKILL, you're circumventing the normal shutdown process of the agent, which leads to the issue you're seeing.
If you effectively "pull the plug" on the agent (and not giving it a change to clean up properly), you're going to have to manually clean up the attached (but dead) shares. If you send SIGTERM or SIGINT, these will get shut down properly and your agent will restart cleanly.
And you can use zrok2 overview to see the contents of your account, and zrok2 delete share to delete any dead shares attached to names. You for sure do not need to "delete every share in the account on each startup".
Thanks for looking into this. I checked the actual restart records. PM2 runs /opt/homebrew/bin/zrok2 agent start in fork mode, and on October 15 at 17:46:48 and 18:03:17 its log says it sent SIGINT to zrok2-agent. On both occasions the agent then logged stopping and preserving reserved share ... on controller for reattach within milliseconds. The newly started agent encountered 409 shareConflict less than a second later. So these failures occurred after the agent received the graceful signal and preserved the named share itself.
PM2 has no explicit kill_timeout configured, so its default 1.6-second deadline is worth increasing as a separate safeguard. But the preservation step had already completed before the conflict in these recorded restarts. I have not restarted the currently active shares just to reproduce the outage.
Looking at v2.0.8, the agent preserves a reserved share during shutdown, but registry reload calls SharePublic again. The public share path appears to create a new share, while the controller rejects a name still held by the previous share. Is there a reattachment path for a named public share that I am missing, or is this a gap in v2.0.8?
You are right about cleanup: zrok2 overview and zrok2 delete share public:<name> let us target only the dead share. My wording about deleting every share in the account was inaccurate. The remaining problem is the manual cleanup required for an affected named share after a normal restart.
This sounds suspect to me... in the zrok.io environment, I would surprised if the full cleanup were done in less than a second. It's possible, but it's unlikely.
In normal use, there's the agent process itself (zrok2 agent start)... and then there are the zrok2 share <public|private> --subordinate and the zrok2 access private --subordinate processes, which actually service the shares and accesses. It's possible there's something going wrong either on macOS, or on macOS under PM2... the agent process records the registry/state, but it's the share/access processes that do the actual cleanup with the service. If that's not happening properly for any reason, then you'll end up in the situation you describe.
Have you tried running zrok2 agent start in a plain terminal, and doing a normal ctrl-c exit, and watching what happens? Does that work properly on your system? If so, then there's a delta between that and what PM2 is doing when managing these processes.
Alternatively, you could also just let PM2 manage individual zrok2 share processes, rather than inserting the zrok agent... the zrok agent is a process manager also, and two layers of process management might be causing issues.
Not saying there aren't bugs in the agent... or cases that haven't been considered... there probably are... but working with the grain might get you solid more quickly.
Hello Michael, Thank you for your prompt replies.
Honestly is just an issue of starting and restarting the agent. Hoping that after the restart, it brings all shares up again. But instead it complains that there is already a registered share and suggests to delete it first. Which breaks the usability of the zrok agent.
I recorded a video showing this. Maybe this is by design and I'm using it wrong.
zrok2 create name demofailapp --namespace-token public
zrok2 agent start
In another terminal
zrok2 share public http://localhost:3001 --name-selection public:demofailapp --headless --force-agent
Then back to the terminal running the zrok agent.
Ctrl C
Then try to start the zrok2 agent again.
zrok2 agent start
And that's when it fails. to lift up the share again. Is this by design ?
Do we need to delete and release the share from the agent, recreate everything again before restarting ?
@michael.quigley
I cannot reproduce this on Linux. It is possible this is a macOS-specific issue, but I do not have a mac to test on. Here is my result:
First, I start a clean agent using zrok2 agent start:
$ zrok2 agent start
[   0.001]    INFO zrok/v2/agent.(*Agent).Run started
[   0.001]   ERROR zrok/v2/agent.(*Agent).Run error reloading registry 'open /home/michael/.zrok2/agent-registry.json: no such file or directory'
[   0.001]    INFO zrok/v2/agent.(*Agent).manager started
[   0.001]    INFO zrok/v2/agent.(*retryManager).run started
[   0.001] WARNING zrok/v2/agent.(*Agent).remoteAgent unable to load agent enrollment: open /home/michael/.zrok2/agent-enrollment.json: no such file or directory
[   0.001]    INFO zrok/v2/agent.(*Agent).gateway started
If I list the zrok2 processes at this point, I see:
$ ps ax | grep zrok2
2982459 pts/10   Sl+    0:00 zrok2 agent start
2982566 pts/12   S+     0:00 grep --color=auto zrok2
Then I start a public share, attaching it to a name:
$ zrok2 share public -n public:q-testing-2 localhost:9090
token:"7e2gr1qh0oci" frontendEndpoints:"q-testing-2.shares.zrok.io"
I can access the new share:
$ curl -I https://q-testing-2.shares.zrok.io
HTTP/2 200
date: Tue, 27 Oct 2026 17:52:20 GMT
content-type: text/html; charset=utf-8
If I list the processes now, I'll see:
2987460 pts/10   Sl+    0:00 zrok2 share public --subordinate -b proxy --name-selection public:q-testing-2 http://localhost:9090
2991150 pts/12   S+     0:00 grep --color=auto zrok2
There is 1 process for the agent itself (zrok2 agent start) and a second process (zrok2 share public --subordinate) that was spawned by the agent when I started the share. Every share or access managed by the agent will have a --subordinate process.
If I ctrl-c the zrok2 agent start process, there will be a few seconds where the zrok2 share public --subordinate process is still around... at this point that process is doing the cleanup/housekeeping for the share I created. When that process is gone, the share will be cleaned up.
What's important is that if I start a new agent before that process is done cleaning up, I can run into the 409 error that you've encountered. If I wait until that process exits, the agent will re-start the share:
$ zrok2 agent start
[   0.001]    INFO zrok/v2/agent.(*Agent).ReloadRegistry loaded 0 private accesses
[   0.001]    INFO zrok/v2/agent.(*Agent).ReloadRegistry loaded 1 public shares
[   0.001]    INFO zrok/v2/agent.(*Agent).SharePublic executing '[zrok2 share public --subordinate -b proxy --name-selection public:q-testing-2 http://localhost:9090]'
[   0.001]    INFO zrok/v2/agent/proctree.StartChild: executing 'zrok2 share public --subordinate -b proxy --name-selection public:q-testing-2 http://localhost:9090'
[   3.495]    INFO zrok/v2/agent.(*Agent).ReloadRegistry restarted public share 'http://localhost:9090' -> token='o21th4awm2uf', frontends='[q-testing-2.shares.zrok.io]'
[   3.495]    INFO zrok/v2/agent.(*Agent).ReloadRegistry loaded 0 private shares
[   3.495]    INFO zrok/v2/agent.(*Agent).ReloadRegistry reload complete
[   3.495]    INFO zrok/v2/agent.(*Agent).manager adding new share 'o21th4awm2uf'
[  13.111]    INFO zrok/v2/agent.(*Agent).SharePublic.func1 map[method:HEAD msg:access path:/ remote_address:[]]
And I can access the share:
HTTP/2 200
date: Tue, 27 Oct 2026 17:53:07 GMT
And you confirm that you're running v2.0.8? What is the output of zrok2 version?
It's possible that the --subordinate process termination handling isn't working correctly on macOS.
I might have a change for you to try in v2.0.9 to see if it improves things on macOS.
v2.0.9 is out. This version includes a re-designed agent subsystem. When running public shares in the agent with a name selection (a "reserved name"), the agent process manages attachment and detachment of the shares to the selected name, rather than delegating it to the --subordinate share process.
This should address the issue you're seeing.
v2.0.9 now includes a smoke testing harness for this exact scenario, on all 3 supported platforms (linux, windows, macos).
Seems to be working now in this version. I'll keep testing. Thanks
