The Python SDK fails to dial and bind when running under Windows
openziti.version()->(b'1.0.11', b'g92c7d63')- Python 3.10.11
- Windows 11 Enterprise
- Bind application was OpenZiti echo server example
- Note: Launching the same folder under WSL (Ubuntu) works fine
Both problems are related to socket handling differences under Windows / Linux.
I suspect the Python SDK has not been tested under Windows.
There is a related Issue in GitHub Python SDK. It was originally raised for the dial problem, I added a comment about it also affecting bind.
