I am working through this…
https://openziti.github.io/ziti/quickstarts/network/hosted.html
I got stuck with the following error
quickinstall.sh: line 6: syntax error near unexpected token `(’
# now download, source, and execute the expressInstall function
source <(wget -qO- https://raw.githubusercontent.com/openziti/ziti/release-next/quickstart/docker/image/ziti-cli-functions.sh); expressInstall
The following is the contents of quickinstall.sh
set -a
source .ziti/quickstart/config/config.env
set +a
Hi @markamind, are you able to wget the file without trying to source it? Basically just do: this one line in two:
expressInstall
I run / test this script using ubuntu but there are shell variants on linux that sometimes cause issues like this.
I saw you mention oracle cloud on another issue. Is this with Oracle linux? Maybe there is a problem with their image which doesn’t like doing this in one line. Or - can you tell me exactly what variant of linux you’re running? If I can reproduce the issue we can fix it for everyone.
Try doing it as two separate steps first thoguh
Also do you know what bash version you have? I found this SO post that indicates bash 3 doesn’t with with process substitution . I wonder if you have bash 3.2. If so, doing it with two steps should work…
Awesome… I will test this out tomorrow and keep you updated.
I find this so exciting. I never ever imagined I would be doing networking in a million years…
I got it to work with some bash magic.. I don't write much bash.. but are starting to get into it now.. lots of small steps
Step 1.. download the file
Step 2.. call the function within the file (I did not know this was possible
you need to use the && command.. (never stop learning)
. ./ziti-cli-functions.sh && expressInstall
My first Ziti controller installed
