Hello,
I am using zrok for testing to setup my home network. Some of the nodes in the UI at api.zrok.io are unclickable for no apparent reason. I have created some nodes with WebDav, proxy and Caddyfile using frontdoor, and with normal terminal commands. But I haven't been able to figure out any pattern. As a result I cannot delete some of the nodes. Is this a bug? and is there another way to manage my nodes from terminal commands etc.?
Are you using Brave? There is a setting in Brave that prevents the UI elements from being selected. I don't have Brave in front of me at the moment, but I can try and dig it up if you can't find it.
