ZAC - creating a second admin users
I was in dialog with @TheLumberjack who mentioned that you can create a new admin user using the following command
ziti edge create identity user Admin3 -A --updb newAdminpwd
This worked… but then… I tried to log into ZAC using that account… which did not work.
do you need to enrol the admin user for this to happen?
Chris also mentioned the the password was unable to be changed for the new admin user that was created
would this happen if the user was not enrolled
The reason for doing this is… that one of the standard practices is to delete/disable the admin user once the system is setup…
can you disable identities rather than deleting them?
what is the recommended identity lifecycle?
