Back to the login now... where I am getting a different error message.
$ zitiLogin
The connection to the server instance-20220317-1005:1280 was refused - did you specify the right host or port?
One thing that I needed to do that may have caused this was to upgrade the golang server
Apparently it did not want to run on V1.16.. so I upgraded it to 1.18.. which too me a while to work out..
Let me know if you have any tips
Hmm⦠I am thinking I may need to remove the .ziti folder and try again⦠I thought I deleted the identity⦠but maybe there was something still hanging around
[ 14.716] ERROR edge/controller/model.(*IdentityHandler).CreateWithEnrollments.func1: {error=[duplicate value āreflectClientā in unique index on identities store]} could not create identity in bolt storage
[41611.420] INFO : http: TLS handshake error from 10.0.0.41:58238: remote error: tls: bad certificate
[50117.938] INFO : http: TLS handshake error from 10.0.0.41:58854: remote error: tls: bad certificate
[50630.822] INFO : http: TLS handshake error from 10.0.0.41:58908: remote error: tls: bad certificat
These are the types of reasons why I donāt remove the entire folder and delete services, config etc. The second error looks to me like a connected tunneling app is trying to connect but cannot because the pki was replaced, thus the controller wonāt permit the tunneler to attach.
As for golang 18, thatās a new one for me. Iāve not had that particular issue yet. Are you building the code yourself? I wouldnāt have expected you to even need go to run thingsā¦
Thanks⦠now that I reread the error⦠it makes sense⦠I have reinstalled it so many times⦠its time to just restart from the topā¦
In relation to golang⦠I thought I had everything in place for the reflect server client example⦠then⦠as I run the main.go file⦠it said that a module was not compatible with v.1.6⦠this was the default version Oracle provides with its yum serviceā¦
That triggered a whole bunch of things as I needed to install git and then work out how to migrate the golang server into the right folder⦠all done now though⦠the first time is always the hardest
What I preparing for a situation where I zitify an application server like Apache⦠and then use it to host applications on the dark side of the net⦠this is probably a month away at this stage
Oooh. It wasnāt clear to me you were running the reflect example. That would need go 1.17+ so yes, now that makes total sense.
Quick update.. I deleted the .ziti folder and rerun everything.
Success
go run main.go server -i reflectServer.json -s reflect
INFO ready to accept connections
INFO connection to edge router using api session token .......
