After restarting zrok-controller the error has disappeared. Then it appears again. I restart. Then the error appears again. I restart…..
Some times there are no errors at all in sys log but Zrok agent does not work : curl returns nothing.
zrok version v1.1.3
ziti version v1.6.7
"file": "/__w/zrok/zrok/controller/agentPing.go:48",
"func": "github.com/openziti/zrok/controller.(*agentPingHandler).Handle",
"level": "error",
"msg": "error retrieving agent version for 'zID' (name@domain): rpc error: code = Unavailable desc = connection error: desc = \"transport: Error while dialing: unable to dial service 'agent remoting token' (dial failed: token is malformed: token contains an invalid number of segments)\"",
"time": "2025-08-23T07:36:47.958Z"
I have tried with version Zrok 1.1.2-1. After some time zrok agent remoting stops working. then it starts to work again. Then it stops. And so on.
Conclusion: Ziti 1.6.7 does not work with Zrok 1.1.2 & 1.1.3.
Everything becomes normal with ziti-router 1.5.4 and Zrok 1.1.2-1
There is another problem with zrok 1.1.3 : zrok-agent 1.1.3 access stops working suddenly.
"_context": "ch{edge}->u{classic}->i{zId/NMp2}",
"chSeq": 96,
"connId": 9,
"edgeSeq": 0,
"error": "invalid api session id, expected 1ad4eb3a-72d7-4421-b879-651fa4b00466, got 2092ef26-98c3-40ee-885d-61372bf1f4f2",
"file": "github.com/openziti/ziti/router/xgress_edge/listener.go:199",
"func": "github.com/openziti/ziti/router/xgress_edge.(*edgeClientConn).processConnect",
"level": "warning",
"msg": "failed to dial fabric",
"time": "2025-08-23T10:10:25.626Z",
"token": "eyJhbGciO......"
journalctl --since "12 hours ago" -g 'failed to dial fabric' | wc -l
3104
Zrok v1.1.2 works without this problem.
