ZROK not working
Hello Everybody,
Thanks for the help in advance.
I am new to zrok, successfully set it up, and left if running for a few days. However, the connections timed out and since then, it is refusing to connect. "zrok" enable " works no more. I tired to disable and re-enable and it still did not work, even though my dashboard shows all the connections (I was trying to use it for federated learning using NVFalre)
Error messages are found below:
zrok enable
there was a problem enabling your environment!
you are trying to use the zrok service at: https://zrok.io
$ zrok config set apiEndpoint
[ERROR]: error creating service client (client version error accessing api endpoint 'https://zrok.io': Post "https://zrok.io/api/v1/clientVersionCheck": dial tcp 104.199.116.47:443: i/o timeout: Post "https://zrok.io/api/v1/clientVersionCheck": dial tcp 104.199.116.47:443: i/o timeout)
zrok disable
[ERROR] no environment found; nothing to disable!
'https://zrok.io' is not a valid API endpoint.
Run zrok config unset apiEndpoint and then try enabling again.
