Zrok background mode
Does Zrok have a background mode, headless mode still output to console, is the only to have have it run in background is to use nohup ?
Hey there @mbenachour, since you mentioned nohup, I think you're looking for a Unix solution.
There's a Linux package you can install on distributions that use Debian (deb) or RedHat (rpm) packages.
Here's a shortcut one-liner:
curl -sS https://get.openziti.io/install.bash | sudo bash -s zrok-share
Here's the "frontdoor" documentation about this, including how to set the account/enable token and share target as env vars: zrok frontdoor | Zrok
You can approach the same use case of a reliable background service with systemd or Docker.
