Zrok increase timeout
Hello. Zrok responds 504 Gateway timeout when 60 sec elapsed. I need to increase response timeout because my web app need more than 60 sec to respond. How can i do this ?
There isn't (currently) a mechanism to configure this. Let me do a little investigating to figure out which components are timing out (I have a suspicion, need to confirm). I'll see what I can figure out.
Michael, thank you. I'll be waiting.
It would be great if timeout will be around 300 seconds (5 minutes).
Hello, Michael. Is there any news?
Unfortunately, if you're using public shares with the zrok.io service, you're going to be limited to a timeout of 60 seconds. This is due to to the cloud infrastructure hosting that front end.
If you're able to use a private share (using a local frontend via zrok access private), you should have a much, much longer timeout.
