Stuck environment returning 500 error
I got a stuck share after few attempts to restart it, I ran zrok2 disable in my terminal, which removed the environment locally. But on the web console it's still there. I tried to refresh the account token few times as it seems to be a workaround, but it didn't do nothing and every time I try to release it, I just get an error 500.
Can you please help me? My environment is DESKTOP-JJN5P7E\Kuro@DESKTOP-JJN5P7E
I got the same... it is happening since friday.. There's a trouble with zrok server suppose. I hope they resolve soon
Just following up here to let you know in case you haven't seen.. Please follow that thread for updates
Hi. Just following up here too. I made this post on the pinned topic but just FYI here to make sure I cover all the bases... [duplicating the summary of that post here follows]
If you had stuck sessions that cannot be deleted, I'm told you should now be able to delete them on your own again. I don't have any I can test myself personally but if someone does and if they could post a follow-up here with success (or failure but let's hope not) that would be appreciated.
Thanks again for reporting the issues and bearing with us while we make zrok better!
